Thema: Re: any idea? (Übersetzer)
Hey Leonardo,
if the pump is working and puts up pressure, the whole system is filled up with oil, the only reason left why the rear end doesn't comes up is imho a valve issue.... or closed in air witch can't come out (Pump is working against an air bubble and so doesn't get enough compression to lift the car hind end).
So, I would say check all the valves in the system if they open and close the right way, be sure there is no air left in the system AND check the electricity on the Valve circuit.
Cheerio
cu Conny [AK]
560SE, 560SE, 420SE.
[Problem] HPF need help for my 560! Anhänge
Leonardo560 1562 05.09.16 11:05
Re: HPF need help for my 560!
Leonardo560 797 05.09.16 20:34
Dorian 935 05.09.16 21:26
Leonardo560 662 06.09.16 00:29
Dorian 816 06.09.16 09:51
Leonardo560 768 06.09.16 20:39
Re: HPF need help for my 560! Anhänge
Leonardo560 836 12.09.16 11:32
Dorian 638 12.09.16 22:47
Leonardo560 594 13.09.16 01:12
Dorian 723 13.09.16 23:30
Leonardo560 742 17.10.16 18:30
Conny 753 17.10.16 19:34
Leonardo560 692 17.10.16 22:21
Conny 625 18.10.16 08:47
Leonardo560 583 18.10.16 16:05
Conny 695 18.10.16 20:49
Leonardo560 602 18.10.16 22:38
Leonardo560 913 21.10.16 13:16
Leonardo560 721 02.12.16 17:01
Dorian 554 02.12.16 22:41
Leonardo560 718 03.12.16 00:14
Nemo 614 03.12.16 09:57
Leonardo560 578 03.12.16 15:03
Leonardo560 547 20.02.17 14:05
Leonardo560 486 21.02.17 19:22
Dorian 649 21.02.17 20:57
Conny 511 22.02.17 11:18
Nemo 598 21.02.17 20:49
Leonardo560 583 23.02.17 10:25
Re: any idea? (Übersetzer) Anhänge
Leonardo560 538 16.06.17 10:50
Leonardo560 497 16.06.17 18:02
Dorian 471 18.06.17 16:23
Leonardo560 527 19.06.17 01:22
Leonardo560 298 19.06.17 14:58
Conny 494 19.06.17 16:52
Re: It seems to me that the check valve in the level controler rear axle is activated
Dr.R.Becker 772 19.06.17 19:20
Leonardo560 466 20.06.17 00:47
Re: still no manual?
Nemo 321 21.06.17 16:20
Leonardo560 345 21.06.17 16:55
Re: MB Manuals on CD and DVD
Dr.R.Becker 725 21.06.17 17:28
sorry
Nemo 446 21.06.17 18:10
Dr.R.Becker 358 21.06.17 17:57
Leonardo560 346 21.06.17 19:05
Dorian 275 21.06.17 22:56
Leonardo560 483 22.06.17 00:17
Leonardo560 242 23.06.17 20:32
Re: It seems to me that the check valve in the level controler rear axle is activated Anhänge
Leonardo560 265 23.06.17 21:25
Leonardo560 250 24.06.17 13:45
Dorian 335 24.06.17 21:55
Dorian 260 24.06.17 22:38
Leonardo560 243 26.06.17 13:08
rear pressure pipe or regulator check
Nemo 237 26.06.17 15:37
